Semi transparent acrylic material
  • Semi transparent acrylic material
    Anyone knows how to create this material. Semi transparent, translucent acrylic material ?
    You can use the refraction glossiness (set it to 0.5 for example) or use the frosted glass from the library as a starting point.
    Best,
    Peter (peerman)
    AMD Ryzen 9, RTX 2080Super, ArchiCAD 24, Vectorworks 2020, Sketchup 2021 Pro, Vray Next for Sketchup, Skatter, Twinmotion 2020
      I tried it, but it casts sharp shadows. Is there anyway to overcome that ?Thanks anyways
        To achieve soft shadow edge, increase light/sun size
          Thank you very much. Isn't there any other way?
          Cuz I have few other windows that gets direct sunlight from them
            This is not the same as you described (translucent acrylic material) but I think it will give you more relevant result to your inspiration.
            2sided material and sun size increased. https://docs.chaosgroup.com/display/...+%7C+Mtl2Sided
            Left image with sun size 1. Right image with sun size 1.2
              You can try getting the diffuse lighting effect by enabling caustics in GI. I don't recall the specifics now, I had set up something like that in a previous version of V-Ray for SU. As peerman says, you need to have semi-glossy refraction set up in your material.
                Here is a test render with Refraction Glossines 0.1
                  You can see the problem Tharusha is trying to solve - in your example the sun casts sharp shadows on the wall. The shadows should be diffused by the translucent material.
                    I tried to turn off "affect shadows" which turned off the sunshadows. Maybe with an additional rectangle light to simulate the daylight coming in could help?
                    Best,
