HDR and Rendering
  • HDR and Rendering
    whenever i render my HDR image does not show up in the finished rendering, it is in the Preview image on screen though
    It's known as an alpha channel, if you save an .EXR or .HDR you need to go into photoshop and select the beauty layer, then click on the layer > layer mask > from transparency.
    Your sky should then reappear with a mask in Photoshop.
      i got it working with the trial, and never had to do that
        any help on this? need to get a rendering or 2 out for my company, doesnt help without the HDR working
          Dave, see your private messages, please.
          Ana Lyubenova
          Product Manager
          www.chaos.com
            i do not use Photoshop, i have GIMP tho
              any other option? we do not have Photoshop, we have Photo Elements, i really need to do a rendering
                If you save the image either as .jpg or .bmp, the HDR background will be saved (see attachment)
                If you save it as a .png, you will need to do what chadstevens had already told you but in GIMP:
                1. Right click the layer in the layers dialog.
                2. Select Add Layer Mask from the context menu.
                3. Initialize Layer mask to: Transfer layer's alpha channel.
                4. Click Add
                5. Go back to the layer's dialog. You will see a small preview of the mask next to the original layer. Right click the layer mask and select: Delete layer mask. This will discard all alpha information and will show up the background.
                Ana Lyubenova
                Product Manager
                www.chaos.com
                  got it! ....wow ,thanks
