Hi i'm still pretty new to Phoenix FD, I have large scale destruction that I made with TP that has debris flying every where. Im going to put a gasoline type of explosion in the center but I also want some smoke fire trails on the pieces. Whats the best workflow when using Phoenix FD with TP for something like this? I've done these kind of effects with FumeFX but i'm seeing if i can get similar results using Phoenix FD .
Phoenix FD with TP destruction
Hey,
You gotta add the pieces into a Phoenix Source and this should be it. Depending on the kind of emission you need, you can switch between Brush, Inject or Surface force modes of the Source.
In case the geometries do not emit, we're making some changes in the nightly builds that would allow it, so ping us and we'll update you when you can grab a latest nightly.
Cheers!Svetlin Nikolov, Ex Phoenix team lead
I tested and it seems to emit fine from xmesh or alembic. THey have material ID's the fragments but not object IDs. But maybe its not so important since they just need to be like fireballs with smoke trails. I tried by starting off with the gasoline explosion preset but im having a hard time getting little fireballs with trails on the fragments. Can i combine two fluid containers. One for the gasoline type explosion and one for fireball trails? Just trying to get something that looks kind of like this https://www.youtube.com/watch?v=w1iJX7tycYw. I also noticed that the gasoline explosion preset defaults the scene scale to 17. Is that correct? since in the userguide it says that 1 is for realscale. Everything in my scene is in real scale. I have all the fragments as one object. Should i export them as separate objects. Is that why i dont get trails?Last edited by adrian_camarena; 27-07-2018, 11:28 PM.
Hello,
There should be no problem creating two grids - by default they will interact with each other correctly so it should work out of the box.
The scene scale of the gasoline explosion scales according to your scene scale in order to get a decent result. Feel free to change the scene scale if you think it doesn't fit the look you are after. Overall the preset it's just a starting point, that should be tweaked accordingly.
The other thing is that in the gasoline explosion preset the PHX Source emits for only 1 frame.
The trails should emit for a few frames so you can see them. You can make another source just for the trails and use the original one for the base explosion.Georgi Zhekov
Phoenix Product Manager
Chaos
