Max v2.2 nightly: Destruction Dust and Fine Debris [09 October 2014]
    Maybe you should check our doc page:
    https://docs.chaosgroup.com/display/PHX3MAX
    About refractive index:
    https://docs.chaosgroup.com/display/...er+%7C+PHXFoam
    I didn't understand what do you mean in the last message?
    George Barzinski
    QA Phoenix FD
      where is reffractive index of setting PHXFoam phoenix 3!!!!?
        You had this option in Phoenix 2 PHXfoam!
          and tell me please what settings renderer should be that would have turned out like in the lesson?
            • #21
              Please, update your knowledge with our documentation because a lot of things are changed since Phoenix 2.
              The link I've shared already answer to your question - Refractive index option is now in Particle shader node (in Cellular/Bubbles/Splash rollout)
              George Barzinski
              QA Phoenix FD
              • #22
                how to set this parameter 1.7 in phoenix 3.0?
                • #23
                  If you are in Point mode, this parameter does not affect the rendering neither in Phoenix 2, or 3. You need to set the Mode to Cellular/Bubbles/Splash and then a new rollout will appear with the Refractive index parameter. However, in Point mode the rendering is faster, but there are no refractions and thus - the refractive index is not used.
                  Cheers!
                  • #24
                    n this lesson, is it better to use a point?
                    I just can not get the same effect
                    • #25
                      Yup, Point mode will be better for dust and sand, you don't need the bubbles in this case. How does your setup look so far?
                      • #26
                        • #27
                          Hmm, looks like your fragments might be moving too slow and they cannot pull the smoke along. How many frames into the simulation is this screenshot?
                          • #28
                            • #29
                              but what about the rendering and density, etc?
                              • #30
                                I can not achieve the same result for 5 days already
