VRay Proxy subdivision & visibility overrides
  • VRay Proxy subdivision & visibility overrides
    is there any way to override subdivision & visibility on VRay Proxy (alembic) with Maya render setup?
    Subdivision seems to work fine, you can just add a layer override to the attribute.
    By visibility - which visibility attribute are you referring to?
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      In my scene, VrayProxy is loaded with Alembic file containing multiple poly mesh (nested under groups)
      mainGRP
      |---subGRP01
      | |-- ballMesh
      | |-- boxMesh
      |---subGRP02
      | |-- coneMesh
      | |-- cylinderMesh
      |---subGrp03
      | |-- torusMesh
      Now how can i override subdivision & visibility of specific group or mesh ??
        Do you need to just change the value? Or do a render layer override?
        Alex Yolov
        Product Manager
        www.chaos.com
          New render setup override, Like this https://youtu.be/LnoDgVUZjmc
            The visibility lists seem to be unsupported for the render setup, I'll log that as a feature request with the devs.
            As for the subdivision attributes - you should be able to override them just like any other attribute using the new render setup.
            Alex Yolov
            Product Manager
            www.chaos.com
              Thanks, is there any plan to integrate MaterialX 1.36 ? it will make life easier to manage shading network and material overrides.
