Motion blur issue in Horizon
  • Motion blur issue in Horizon
    hi , i have a problem, when i use motion blur in render , one black line creates in horizon. i tested everything for Disappear it but nothing happened.
    tnx
    Hey,
    First make sure to get a latest nightly build. Here is how to get it - https://forums.chaosgroup.com/forum/...nightly-builds
    If the problem still persists and you are using the Ocean preset, in your scene probably there is a V-RayPlane node. If you hide it the horizon should render fine.
    Note that if you hide the VRayPlane and there are particles in your scene they may flicker without a bottom plane below the ocean surface so you might need a large enough plane below the surface to act as a botom.
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Originally posted by georgi.zhekov View Post
      Hey,
      thanks for reply
      but i hide and delete vray plane and this problem still persists. i said i tested everything ( change camera , change Off-screen Margin Value , ect ) but that didn't solve.
        Hey,
        i found it , Fog color in material makes this problem. but i didn't find solution still.
          What version of Phoenix and V-Ray are you using?
          Can you share with us the scene so we can take a look?
          Georgi Zhekov
          Chaos
            Vray 3.60.03 _ phoenix 3.10.00
            also , phoenix's particles ( foam, mist , splash) have conflict with translucency in material, when i make Special water material with fog and translucency and i render water and foam together , 3ds max crashes.
              Hello,
              For the crashes it's best to get the latest versions of V-Ray and Phoenix and if they are still reproducible we'll take a look.
              As for the black line near the horizon it happens because of the reflection glossiness and the lower camera angle. If you set the reflection glossiness to 1 or you move the camera up a bit it should be gone.
              Though this shouldn't happen and I have logged it in our bug tracking system.
              Thank you,
              Georgi Zhekov
              Chaos
