Rendered mode doesn't show procedural textures
  • Rendered mode doesn't show procedural textures
    Rendered mode doesn't show procedural textures, instead of that, it shows only color.
    I believe that this is normal. Procedural textures are generated by vray at render time and Rhino's Rendered display mode is only an approximation.
    www.marinevisuals.com
    3D Visualization for the Marine Industry
      This may be the reason why. The same happens to the Blend Material and others. I must say that it is very uncomfortable in easy situations and making things undoable in more difficult cases. Is there any chance to improve that?
        V-Ray procedural textures and more complex materials cannot be displayed natively in Rhino. Currently, only diffuse color, bitmap textures and some additional basic parameters are synchronized between V-Ray and Rhino.
        The "Show in viewport" button in V-Ray enables a degree of viewport customization without affecting the render output (https://docs.chaosgroup.com/display/...#Bitmap-Bitmap)
        Peter Chaushev
        Let's keep in touch
          Why you don't like the interactive display mode? Do you miss something?
          I tested the interactive mode for a simple cube and my impression is, the interaction is quite lag. So, I applied a checker pattern and it needs 15s to see a change. If the GI calculation is the problem, than maybe a flat rendered mode without GI and shadows could help.
            I found now, if I don't use the Rhino viewport Vray display mode for the interactive output, the speed is great. The regular interactive frame buffer output is quite fast. So, it looks like the Rhino viewport connection needs to be optimized.
              I'm rendering architecture, that means that I have big scenes. I'll try this method Micha but I'm afraid that my scenes are badly optimized and it would be very annoying to run interactive render just to map texture. Maybe I can try isolate objects before to make it faster.
              This "show in viewport" button is handy, I didn't notice that function. Thanks.
                A VPR (Viewport rendering) scaling function is being prepared to ensure the ability to preview even very heavy scenes without major slowdown. This will not eliminate the load time upon initiating the renderer. Another handy workflow is to isolate only the parts of the scene which you are interested in previewing either via the Rhino Visibility control or the project's layer structure.
                Regards,
                Ana
                Ana Nedyalkova
                V-Ray for SketchUp | V-Ray for Rhino | QA
                www.chaosgroup.com
