small geometry thing
  • small geometry thing
    I´m struggling with this small details.
    This is the geometry:
    Then I´ve modified like this:
    And the result is this:
    But those lines are way too dark now, so I made them thinner and the problem rise up again.
    My settings are pretty much vray standard:
    Adaptive 0/3
    preset at medium
    I took irr to high and it was even worst.
    I´m using only environment lighting (simulate a cloudy day)
    Am I missing something or with Vray this kind of details are not a possibility?
    Thanks in advanced
    try lowering your AA threshold below the .1 default.
      It is better, thanks. But , what is all that grey stuff (shadows or stains) on that wall?
        this is with preset at high
        I´ve added an arrow in case you don´t know what I ment.
          For really super fine stuff like this, you may not want to use the adaptive AA, but the Simple two level, at a setting of 1,4, or 2,4... 2,4 will be expensive. I have found it to be better and more responsive to these promble areas which adaptive tends to over smooth.
            Yeah, it looks a bit better. It is slower though.
