This happens to me too from time to time, especially if I am to close to an object and the scene is really big.
is it possible it has to do with dof settings?
Dof is off, but I had it on some time before it happened.
If I reset the asset editor, which setting will be reset? Just the camera, output and DOF, or also environment, lighting, volumetric etc etc...In which case I'd loose a lot of my scene set-up....
We were aware of this occurring when using custom render settings loaded from a previous V-Ray version (2.0 and older). Please be informed that loading ‘.vropt’ or ‘.visopt’ files created in previous V-Ray versions is not recommended. Some outdated parameters may cause unexpected results.
Keep in mind that, being part of the render settings, any Environment textures will also be disconnected and colors reset.
