The assign material by plug-in was removed in NEXT and it makes assigning materials to layers a real pain.
If you have even just a couple of nested layers the names are irritating to see in the small assign to layer context menu as they are cut off and you have to hover to see each one.
Assigning a material to multiple layers is a massive chore now, you must individually assign each layer, one by one, compound this with not being able to see the layer names, it takes even longer. Before i could just select all the layers in rhino, check the plugin box and it was done.
I really hope you can bring this back or at least make assigning materials in v-ray much better.
