final render problem- difference frame buffer final image
  • final render problem- difference frame buffer final image
    hello, I always have a problem; I use vray gpu update 1.3;
    as you can see the render that I see in the frame buffer is completely different from the render that I save (png or jpeg is the same); the image is always very dark and then I modify it in fotoricco. But I don't understand why it happens.
    How can I solve?
    The first is the frame buffer; the second is the render image; the third is the image in post-production (with some aberrations)
    Thanks for the support
    Matteo
    is it possible that the problem is the layer display correction? (I have it by default)
      Indeed, the display correction states "Display Only", so any change made to it (f.e. exposure) won't be carried over.
      Try ticking on "Save RGB Primaries conversion to Image" to see if that makes a difference (in which case, you're likely not rendering properly under LWF.).
      If everything fails, feel free to send support a vrimg (from the history folder. right-mouse click on the history entry for a quick way to get to the image.), and they'll figure it out for you.
      Lele
      emanuele.lecchi@chaos.com
      Disclaimer:
        thanks for the support Lele;
        i tried with rgb primaries conversion but it is always the same.
        I contacted the support with a ticket because I have some urgency for this job delivery and let's see how to solve the problem.
        I think it's some display / gamma / color correction problem
        thanks a lot
        Matteo
          You can always ctrl+C to copy the image you're viewing into clipboard, and paste it back into Photoshop.
          It should look identical (provided PS is set up right.).
          Lele
          Disclaimer:
            what format are you saving out to from vray? If its exr, theres your problem. Save to png from Vray and itll bake in your colour corrections.
            Website
            https://mangobeard.com/
            Behance
            https://www.behance.net/seandunderdale
              hi, thanks for the support;
              I tried to do ctrl + c and copy the image in photoshop;
              with this method it is the same as the frame buffer;
              I always save the image in 48 bit png or jpeg
              I attach image copied in photoshop
                these are pictures:
                screenshot - test 2 without layers - test 3 with layers
                  Hi matteo_speri,
                  Can you please check if you are saving the effectResult channel? Note that all the Color corrections, Lens Effects, Denoise, LightMix corrections are saved within the effectResult.
                  Viktoria Dimitrova | chaos.com
                  Team Lead, Cosmos Asset Creation
                    Hi, this is the image in the channel effects result; is the same..i try with the gamma.. thanks
                      Hi having the same issure !
                        Hi jarmo2127 could you describe your issues in details? There is a lot commented in this thread and the thread and the last post is from 2021. What are your V-Ray and 3ds Max versions? A visual example of your issue will be very helpful as well.
                        Vladimir Krastev | chaos.com
                          Hey Vlad. I was using Rhino 8 vray .. it seems to be working ok now but I its not giving me the final result channel only RGB thanks
                            Hi jarmo2127 if you are a Rhino user please post your question in the Rhino section. In 3ds Max you will have effects result channel if you have enabled it or if you are using VRayDenoiser. I am not sure how things are in Rhino.
                            • #15
                              Thanks sorry for that Vlad.. hey do you know if I can import a vmat into 3dmsax from rhino ? Cheers
