Archiving Max file with cosmos objects?
  • Archiving Max file with cosmos objects?
    Im trying to archive a max file to render over back burner ( and possibly a render farm) i have used many objects and HDRs from Cosmos.
    I had assumed when objects imported into the scene, i woudl be able to archive the entire proejct ( i used the default C drive destinations for downlaod)...and essentially be able to transfer the external refed objects to a shared folder on the network. I seem to be failing. Hope this makes sense, and hopefully there is something i am missing, as locating all assets and moving them individually to a shared folder seems like a real hassel. thanks in advance.
    Haven't tried and wonder what and why it's not working but when I package a scene I use this script: http://www.scriptspot.com/3ds-max/scripts/collect-asset
    Might want to give that a try first.
    Built in package/collect in 3dsMax isn't very good.
    A.
    www.digitaltwins.be
      wow! solved everything in 1 lovely click ( all the TX, all the VRMESH files!) , thanks so much for help.
        Hi, is the script support 3ds Max 2023?
        Jackie Teh
        3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
        AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
        Website: https://www.sporadicstudio.com
        Email: info@sporadicstudio.com
        YouTube: https://www.youtube.com/c/SporadicStudio
          Yeah it's a normal script, should work fine.
          A.
          www.digitaltwins.be
            Thank you for clarified.
            Jackie Teh
