Dome light changes
  • Dome light changes
    I set the Dome light where I'd like to see the sun coming into a scene during an interactive render. But when I switch to a final rendering, the light changes. Attaching an example. You can see the light on the rug in the interactive render screen shot that's missing on a final render. These are low resolution for illustration purposes. Wondering why this is happening. I do have the sunlight on too but it doesn't seem to matter. Thanks in advance.
    But still can see the sunlight on the lower right floor
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
    AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
    Website: https://www.sporadicstudio.com
    Email: info@sporadicstudio.com
    YouTube: https://www.youtube.com/c/SporadicStudio
      Yes but it’s not staying where I want it. Ie: Across the rug as seen in the interactive render screen shot.
        What i mean is, the sunlight on the rug look like a triangle, it look like fake light, do you check your scene, is there any fake light in scene?
        Jackie Teh
          Yes. I know it’s not realistic. It’s not done. I just wanted to show one clear example to illustrate the issue. I don’t understand why the dome light entering the scene will not stay in the same place when I switch from interactive to non-interactive rendering.
            Hard to say without a scene. Simplify the scene and attach (or send) it.
              I figured out what the issue was. I had it set to Infinite Dome. Once I removed it, the sun stayed where I wanted it.
              Thank you all for your responses.
