problem GPU rendering Ocean redshift/phoenix fd
  • problem GPU rendering Ocean redshift/phoenix fd
    Good morning,
    I have a problem with the mesh of my ocean with phoenix FD.
    I don't have the same resolution at the grid level and at the ocean itself (see photo).
    When I use vray everything is ok, but when I switch to redshift, and I check the "show mesh" box I get this result that I cannot change.
    it seems that the ocean has much less resolution.
    Can anyone help me?
    many thanks in advance​
    Nobody understand ?
    I would like to point out that the same problem arises when rendering with vantage​
      up
      please.....
        Hey hello!
        Sorry for the delay, but it would be better to post in the Phoenix forums instead of the common section.
        Please try this workaround: select the Simulator and type in the maxscript listener $.oceanforcerenddetail=true
        This will make the viewport slower, but will be a workaround for the issue until we find the exact reason.
        Could you please share the exact Redshift and Phoenix versions you use?
        Cheers!
          THANKS !!!!!
          you are amazing !
          I've been scouring the web for a week and haven't found any solutions.
          you are the best !
          many thanks​
