Vray5 Animated Objects Screed-Lift Reflection/Light Issues On|Off randomly
  • Vray5 Animated Objects Screed-Lift Reflection/Light Issues On|Off randomly
    Hi All,
    I have a problem with the reflections on some animated objects. They go on and off randomly during the animation.
    When they are not animated everything works as expected and is fine. I use bucket mode with brute force and light cache (animation preset).
    The material is "glossy/reflective" with "BRDF GTR anisotropy". But I have changed this several times without success.
    For the general troubleshooting I have tried the following:
    Merge into a new scene
    Reset and readjust rendering parameters
    Playing with the settings "Min/Max / Subdivs / Sample size, etc."
    Checked the geometrie of the objects for errors (faces, normals, edges, etc.)
    Exclude this objects from the nearby affacting lights.
    All without any success - I'm a little bit lost....
    It is not flickering on each frame, but randomly switching on and off.
    There must be a reason for that.???
    Do you have any tip or advice to fix this problem?
    Many thanks in advance for your help.
    Frank
    Hi Guys,
    Fortunately, I have solved the problem.
    Despite checking the geometry STL-Check + X-View (faces, normals, edges, vertex) they seemed to be corrupt.
    I exported the objecte as *.obj and imported it again. After that a few Reset XForm and collapse it to editable poly.
    That does the trick and fixed it.
    Cheers,
    Frank​
