Hey all,
I have some quastions, hope you can help me out.
let me first say im not a noob in vray and i'v saw all the gnomon vray tutorials and some more.
1. Is the Irridance map dependant on the image resolution? (meaning IR map will look diffarent on 640x480 then 800x600)
2. Do I need to remake the IR map everytime i change something with the lights?
3. Are the color mapping settings saved in the IR map? or can be changed after?
4. If I have some animatiable lights and some not animatiable, how meny Nth frame is it recommended to do the IR map incramental? and should i bake the non animatiable lights into the IR?
5. Is it recommended to do the animation in small parts with only the relivant IR map so it wont be huge (like i have now around 30 MB) and will take up longer to load at each frame start?
6. Is it recommended to do the IR map with all the glass in the scene hidden?
7. Is it ok to use DR to make multiple frame incramental IR map?
8. Is there a way to make an attunation of the reflaction or something similar?
any comments or links to other posts or tutorials will be more then welcome.
hope you can help me out with these questions.
Thank you very much
Thank you very much
