yeah. because the free version doesnt have that option and old advanced copies dont have it either
There is the old school way.
If you have a white room with a red carpet, and the red is bleeding too much onto the rest of the room. you can calculate your IR map with a white carpet (just replace texture with a standard white color or a slightly red one if you still want some color bounce) then save that IR map and put back the old carpet texture and then render again using the saved IR map.
You can also turn down the generate GI in the vray properties for the object.
(right click on the object in the viewport and choose Vray properties, or thru the vray system rollout in the render panel, click the object properties button.)
