About dongle
  • About dongle
    I don't know yet which renderer i'm going to use for my work (MR, Final render or Vray)
    I have some concerns about the dongle thing, do you need the dongle only for the installation or you need it pluged each time you use vray ? what if i want vray installed at home and at work, do i have to bring the dongle each morning and leave the office with it to be able to use vray at home ?
    each time you use vray. Yes you'll have to take it with you home and to the office.
    Colin Senner
      Dongle
      This gets me a lot. I usually work from the office and from home and when I forget the dongle I am stuck. When I forget the dongle in one place or the other I end up logging in remotely to the machine that has the dongle. Since I am running xp64 I don't have a driver for my routers VNC app. If I did I could use the office machine as a license server and it wouldn't matter.
      V-Ray is well worth this little hassle for me anyway! I'll probably purchase another dongle anyway, just in case.
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090 X2
      • ​Windows 11 Pro
        So it's possible to get a second dongle for the same license from your reseller ? it could be a solution, one at home and one at the office, withtout the need to buy two licenses of course.
          Dongle
          No, you would need 2 licenses. Don't loose that dongle in transport... you'll be buying a new one full price
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Yeah I take my dongle home with me and export the Max license for use at home for the night, unless i'm doing a render or whatever. I have a zip pocket in my jacket, it's called the VRay pocket. I guard it with my life.
              dongle
              I have mine on my key chain as of late. Now I never forget it.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                Good call as I always have my keys.
                Colin Senner
                  hmm ok so if you lose your key you are in big troubles...
                    A temporary license and a dongle ($30 last time I checked) is a small price to pay for the flexibility.
                      You can also set up a licenseserver over http with the dongle. That way you could leave it at the office and grab the license from home. Or set up a VPN and grab it via the VPN.
                      Regards,
                      Thorsten
                        so you can get a second dongle for 30 dollars and keep it at home ?
                          me loosing the key to my skoda is probably going to worry me alot more than loosing my dongle hehe
                            Thorsten,
                            Where do I find information about setting up a license server for my work machine? or is VPN better and more flexible in other ways too?
                            Colin Senner
                            • #15
                              Well if you have the VRay License Server running than you are ready to go heh.
                              http://licensserver:30304/
                              this shows the statuspage directly. As long as the port is forwarded and the maschine accessable via internet it should work.
                              Regards,
                              Thorsten
