Normal pass suggestion
  • Normal pass suggestion
    Hi there, so just a sugesstion. Imagine a simple cube and some normal map applayed, let say some small cracks for example.
    So when you render the normal pass outputs only original untouched normals of the cube,(FLAT FILLED FACES) without geting in mind normal map applayed.
    Yes it is the geometry normal pass, (and it is corect) but for compositing needs its usless. It will be very helpfull if a little option appears in render passes that allows to get "FINAL RESULT OF THE NORMALS"
    means geometry normals + what normal map chages.
    In the cube example what compositor need is normals that have inside carcks (result of normal map and original normals of the geometry itself).
    all best
    There is a VRayBumpNormals render element, have you checked it out?
      hehe fast responce man, most probably i am on preaty old vray.
      cant see this elemnt in my list.
      Actualy i am more renderman user and just was curious about this.
        arnt the vray demo's timebombed?
