VrayLightMtl
  • VrayLightMtl
    Hi there
    Im new with max and vray and have a question about the values of
    VrayLightMtl.
    As you an see the VrayLightMtl value is set to 5000 that it has about the effect i want.
    Why do i need such high values?
    I get this antialaising failures around the light materials. Probabla because of my high values.
    How can i fix this?
    Thank you
    Howan
    photoshop would be my quick-fix answer
    I've seen a few people post about this and there is no simple fix for it.
    maybe just do 2 passes. 1 at your current settings and one at a very low light value so that you don't need to clamp the colors of the vfb which should be a value of 1 for the light material.
      hmm. you should update to the most recent version also you should send an email to chaod group letting them give you full forum access as a registered owner of vray
