i tried various settings: new incremental, add incremental etc. but each setting seems to save a new map and overwrites the old samples, i did not manage to create a signle irradiance map for a whole object.
i first calculated one side of the object (the imap should have been automatically saved) then i rotated the object and calculated again (with add incremental it should have added the new samples) now if i rotate the object back again and set: from file all the imap-samples from the first calculation have gone.
please correct this. and by the way, what is the difference between new incremental and add incremental?
thanks.
thanks.
