Wood help
  • Wood help
    Hi!
    I'm just new to everything and I was wondering if there is a tutorial for making wood material, since I could see really nice wood for vray for max3, but could not apply the tutorials to vray for rhino.
    Any suggestion?
    Lila
    Wood help
    Hi Lila,
    I did a topic on this a few month ago, maybe you could look at it:
    http://www.asgvis.com/phpBB2/viewtop...ighlight=#2917
    Also there are some tutorial right here:
    http://www.asgvis.com/vfrhino/help.html
    good luck, write something if you have more problem and send your final picture here after
    Jean-Paul Paloux
    Freelance Industrial Designer - Rhino3d v4 - Vray for Rhino
      Wood help
      Hej
      You can find a good material tutorial here.
      It might give you the ability to create wood materials as well.
      http://www.asgvis.com/VfRtw/bin/view/VfR/TutorialM
        Wood help
        Originally posted by Jean-Paul Paloux
        Hi Lila,
        havent seen that earlier...
        nice one
          Wood help
          my god, everyone wants to help a girl here
            Wood help
            a girl...where?
              Wood help
              I have update the material tutorial with a wood material.
                Wood help
                Originally posted by abhikaam
                a girl...where?
                I am supposed to be one
                Thanks everybody for your kind answers!
                I'm going to read everything carefully and work on it!
                  Wood help
                  Hi Lila,
                  All I got is "The topic or post you requested does not exist" ... how come???
                    Wood help
                    oh that's because it's on the general forum that for nwo you cannot access.
                    I don't remember how you do that...long time I've done that. Something to do with the link Usergroup on top of this page, than Subscribe...something like this I think. Or maybe this topic is just for registred users...I don't know. I will do a copy paste just for you
                      Wood help
                      Here the message in the topic you can't access:
                      "Hi,
                      Can someone show a simple tutorial or best a .vismat with the texturefiles and 3dm surface of a wood floor rectangle surface with bump and reflection of a hdr.
                      And keep the original good color of the texture floor bitmap map when rendering with a hdr map. (this is normal )
                      Jp
                      I would like to achieve a good bump and color like this:
                      but for now I have something more like this (also little blurry in addition of a color :S because a bad environment ?):
                      for my scene I use this texture:
                      Originally posted by Micha
                      For shiny floors I use a plastic material: fresnel reflection 1.5 and roughness 0.85 and set reflection at approx. 50 % (130).
                      Also, set a bump map. You need a map with the stripes of the gaps and not so much the structure of the wood.
                      for the bump... no idea yet how to do it good
                      bump ... are you sure you have set a map at the material maps options?
                      it's rendering now
                      but I used a 0.02 and reduce the noise level in Pshop.
                      a few minutes left
                      bump 0.02 and settings.
                      the new bump map...
                      http://www.thefunnel.ca/wood_005x04bump2b.jpg
                      I don't really like the effect on the left side...better on the right side...
                      anyway it's just a test cube that would become a good tutorial for anyone playing with texture and RCM!
                        Wood help
                        Hi Lila,
                        The general forum is available to owners of V-Ray for Rhino only. If you own a license of V-Ray for Rhino then you can email support@asgvis.com for help getting you to the locked forums.
                        Joe Bacigalupa
                        Developer
                        Chaos Group
                          Wood help
                          Thanks for this info! I'm just a 30 days test user right now
                          It's just a bit funny, since most links from User Tutorial points there, and "does not exist" wont let people guess they are for registerd V-Ray for Rhino users only
                            Wood help
                            anyway, in 30 days you'll probably gonna seek in the real forum hopefully.
                              Wood help
                              I wasn't aware the tutorials on our Wiki site referenced member-only forums. Sorry for the inconveniance.
                              [edit]
                              Which user tutorial at http://www.asgvis.com/VfRtw/bin/view/VfR/UserTutorials was referencing member-only forum threads? Thanks
                              Joe Bacigalupa
                              Developer
                              Chaos Group
