In both of the renders i used omni lights insde; in the first one i used linear decay, then i realized my mistake and used inverse decay... The problem is there is light on the both sides of the buildin but only the side i am looking from show lights leaving other side in dark int the second one...
One other thing is sometimes there is a curtain effect on the renders as can bee seen at the first render? Can i control it(i am using a usual curtain inside the building; does it cause that?)
Thank you
Onur Olguner
ps. the material problem presents itself in the second render again joe
