Re: Sun and Detail Enhancement
@Renee
In order to adjust the colors it is advised to use the Acolor type in the texture editor. Simply set you color in the Acolor Map as you would normally, then decrease the multiplier (underneath Type, not the Alpha value) and you should be able to get the colors to work. With textures simply decrease the multiplier and everything should be good to go. Sorry to lead you down the road with no helpers, but I wanted to make sure that you watched the tutorial first. Also, are you using the vray sky for your environment/bkgd or an HDRI?
@Micha
I know it isn't a secret that you wouldn't use the method, but I would encourage you to maybe take a new look at the tutorial now that we have the Physical Sun/sky/cam. Lets let users determine whether they want to use it for themselves. If you want to discuss the "side affects" then we can do that via email or something
@Renee
@Micha
