Urgent for Exam...please [Time Render]
  • Urgent for Exam...please [Time Render]
    Hi guys, i must find a good rapport between quality/time render.
    I use this impostation:
    GI Reflect Caustic: OFF , Refract Caustic: ON
    Primary Engine: Irradiance Map M:1
    Second Engine: Light Cache M:1
    IRRADIANCE MAP
    min -4 max 0
    samples 20
    hsph 66
    yes show calculation phase
    no multipass
    yes randomize samples
    yes check visibility
    LIGHT CACHE
    Sub 1000
    Sample 0.02
    Adaptive YES
    Use for glossy NO
    Filter Nearest -> Interp Samp 5
    QMC SAMPLER
    Ad A 1
    Min Samp 8
    Noise 0.001
    Subv Mult 1
    Randomize Halton
    In Enviroment i use
    GI , bitmap HDR shperical MULTI: 1
    REFLECTION , bitmap HDR shperical (the same) MULTI: 1
    I like render but time is too long [FOR ME...and there is not the water...]
    If i set the noise to 0.01 the noise is toooo much but render more faster (not too much..)
    Please help me, i have an exam
    Re: Urgent for Exam...please [Time Render]
    I would change
    Second Engine: Light Cache M:0.8
    IRRADIANCE MAP
    max -1
    subdivs 60 (If you get splotches, than adjust here first. Maybe you can use a lower value too.
    samples 30 (Don't use to high values - details are lost and render time increase)
    LIGHT CACHE
    Adaptive NO
    Use for glossy YES (important speed up)
    QMC SAMPLER
    Ad A .85 (if you see noise at some materials, than use the mat subdivs)
    Noise 0.01
    Enviroment
    Use a preblured version of your HDRI for GI light. So, the sampling is easier and faster with less noise.
      Enviroment
      I'm trying your setting, but i didnt understand this last pass.
      Mmmm i must blur my hdri? mmmmm i dont have a software that do it i have photoshop 7..mmm
      Anyway, i must put the hdri in GI light and in REFLECTION? (enviroment section)
      Thanks you micha, now i try your setting and i post the result
        with your setting
        As you can see, if i set 0.01 noise there is too much noise...
        but the time render is quite good
          Check out my post on your other thread...I gave a run down of some helpful settings as well.
          http://www.asgvis.com/index.php?opti...5.msg12406#new
            anyone can blur for me this hdr? please i dont have photoshop cs 2
            http://files-upload.com/373026/SM_HD...k1-20.hdr.html
            Please only 900Kb
              Here it is
              http://www.box.net/shared/aom5427qvk
                mmmmm doesnt load that page? mmmm why?
                  Double post? Confusing.
                  My setup is a classical setup method. Please don't ignore "if you see noise at some materials, than use the mat subdivs" , because it's important.
                  For example glossiness <-> subdivs (material option of reflections/refractions)
                  1 .. 8
                  0.9 .. 22
                  0.8 .. 33
                  0.7 .. 44
                  So, you should get best results.
