weird render times...
  • weird render times...
    Hello
    I'm trying to make some interier rendering but the results are revolting. Time is far beyond.
    and the settings
    simple GI
    No transparent materials, litle bump nothing strange what I can see :-\
    thanks for help and suggestions
    Cheers
    Heiko
    Re: weird render times...
    what are your machine specifications?
    1 you have a lot of subdivisions in the qmc gi (15), better, try to get them lower ( default is good) and raise the noise treshold option to 0.01 or 0.008,
    2-also, you can cnange, primary bouncer to irradiance map, the quasi monte carlo is very slow, beacouse it calculates every possible gi solution.
      Yea, those render times don't seem that odd for those settings. As Arbolive said your Qmc subdiv are quite high and a switch to Irradiance map would probably be better. For the Noise threshold a larger number (.05) will render faster and smaller numbers (.005-.001) will render slower. Also you've got a few glossies in ther, so that might be driving up you settings as well. You might also want to post your AA settings as that could be causeing things to take longer as well.
        One of the feet of the chimney is much lighter than the other. The lighting looks strange on it.
        Could it be that you have 2 superimposed mesh on the chimney...? That would explain the long rendering time and lighting...
        marc
          Thanks!
          I will check that and come back...
          //Heiko
