Applying architectural brick material
  • Applying architectural brick material
    It took me a while to figure out how to scale and rotate the material on the surfaces correctly, but now I'm having another issue. When the rendering reaches a corner the bricks on one side of the corner stretch out. The material is applied as an explicit map with a planar projection. All of the U, V and W sizes are the same. Any ideas? I tried to attach an image, but I don't know how.
    Re: Applying architectural brick material
    I would try box mapping instead planar.
      That worked. Thanks a lot.
