Hi, I´m not very sure whether it is bug or my fault but I have some (serious) problems with toon material in SR 1.5.
I tried to change line width by black'n'white gradient bitmap, that wasn't problem at all:
but:
1) I thought it would work the same with line opacity but I´ve noticed that with opacity set to 0 the line was not transparent but white, same effect with gradient map (as you see on the picture). Is there any way to make these lines somehow blend into the material (without decreasing their width)?
3) I tried to use bitmap for line color as well but it doesn't work at all, it doesn't overwrite the original color.
Any ideas?
but:
Any ideas?
