I have vere big problem with the LC calculation during the rendering.. it takes maybe 500% more time then the initial renderings I have done with the same scene, settings etc.
At the beginning I solved the problem with simply copy everything into new file and render it there.. but later this trick stoped to work..
Part of my objects I did with /strech/ and other instruments which make the geometry really complex. Now I remodeled everything in a proper way but the render stays longer. I have the feeling that I can't really clean the LC even pressing reset, dont save and other buttons there on the menu.
It is a living room with sun, sky, IM and LC
I hope somebody can help me
Thank you
Thank you
