Bump vs displacement
  • Bump vs displacement
    Wich one it's faster in rendering time?
    www.leobonilla.com
    Re: Bump vs displacement
    Bump
      defenitely bump but displacement looks much more realistic
        Yap thanks, I tested and in my scene result a dramaticly changed, I rendered with displacement and throws me: 4hr 25min , and with bump 16min.....
        Dual Intel xeon 5550 2.6ghz... ???
        so bump will be...il post images of the scene
        www.leobonilla.com
          Kind of depend on what the use is. If the stuff is far away you will most likely not benefit from displacement. But when up close displacement give better realism than bump.
            The main difference is that the bump give you the illusion of depth, but not deform the geometry at the render time at all. The Displacement actually deform the geometry to give you real depth, but is only at the render time.
            My recommendation is try to use bump, but if you can achieve the desired effect with bump, then use displacement. Also I use displacement for close up and bump for object further away from the camera.
            best
              Thanks Fernando, thats the conclusion I reached, and the one that confirmed my thoughts. Thanks for your time. Ill post later Screenshots of the problem!
              www.leobonilla.com
