Glass Rendering
  • Glass Rendering
    Hi
    I've been modelling in rhino for years and now need to do some photo realistic renders of super high quality, but my rendering skills are good but not good enough to create the type of image I need.
    I've got a engraved glass model which needs to be rendered and wondered if anyone could help me out and point me in the right direction.
    I'm new to this forum sorry if I posted in the wrong place.
    If you would like to see the file I can show it if needed.
    thanks
    Luke
    Re: Glass Rendering
    Hello luke could post an image of what type of glass you would like to use. I will be more than glad to help you out.!
      Re: Glass Rendering
      Hey sorry for the lateness of the reply was working at the weekend, its just a simple champagne glass but i cant get it to look good, but the reason being is that i just use GI for the reflections.
        Re: Glass Rendering
        also this is my attempt at rendering it, can you tell me why the floor never looks like wood either?
          Re: Glass Rendering
          could you send me you scene, you can use megaupload.
            Re: Glass Rendering
            In some cases it depends in what type of texture you are using, if the texture its low quality it would be blurry to the camera.
              Re: Glass Rendering
              http://www.megaupload.com/?d=LVU39PY5
                Re: Glass Rendering
                Im sorry luke, this is a 3d max file, what you can do its save the file as 3d so i can open it with sketchup.
                  Re: Glass Rendering
                  what is the file type, .3d
                    Re: Glass Rendering
                    Hi Dave
                    The file is a Rhino file.
                    Lukeorford, there are different types of noise. Noise produced by the anti-aliasing, lights, etc. In this case the noise looks like big stain, so are Irradiance Map splotshiness. You can increase the HSph Subdivs. Other thing that can produce that king of stain is the HDRI. Try to use a blurry version on the GI Color.
                    Other point is that V-Ray throw less sampler in a dark image, so try to improve the illumination.
                    Here is my test
                      Re: Glass Rendering
                      ok that looks alot better!
                      Did you just have a light set up on that test and no HDRI?
                      Ive never really used lights as i said my knowledge is limited to certain things in Vray
                        Re: Glass Rendering
                        I use two rectangular light. One in the left side of the camera and one in the back right side of the glass. I can give you the scene, because I'm testing the new build of rhino and the scene is not compatible with old V-Ray. In order that you can see the scene I have to redo he scene from scratch. I'm so sorry, but I have no time today to redo the scene. If you want I can do that tomorrow.
                        No HDRI.
                        best
                          Re: Glass Rendering
                          Would you be able to redo the scene for me, it would be of great help.
                          Thanks in advance for all your help with this.
                            Re: Glass Rendering
                            Here is the scene file
                            http://www.mediafire.com/?9ulou6l1k2bgzv1
                            • #15
                              Re: Glass Rendering
                              Thanks alot guys, many Kudos to you all!!!!!!!!
