VRAY NOT RENDERING SU MODEL THAT CONTAIN IMAGES
  • VRAY NOT RENDERING SU MODEL THAT CONTAIN IMAGES
    Everytime I try to render a model that contain a JPEG, BMP, TIF image the 'render'command is ignored. I've already tried the conversion from CMYK mode to RGB mode... still nothing. I urgently need assistance as this is seriously hampering my performance, productivity as well as my quality of work....
    Thanx
    Re: VRAY NOT RENDERING SU MODEL THAT CONTAIN IMAGES
    what version are you using?
    Devin Kendig
    Developer
    Chaos Group
      SU 7 with the latest version of VRAY for Sketchup
        Many people have often mistaken what he latest is. Can you specify exactly what version you have?
          my vray version is 1.84.83
            The latest public version is 1.48.89. So this is a good example of why we don't like it when someone says "latest version".
            1.48.89
            Fixes:
            - Fixed invalid output image path issue that would cause a blank render
            - Fixed issue that caused our gamma settings to be ignored in the material/texture preview renders
            Changes:
            - Made sure that our memory map was getting closed regardless of situation
            ______________________________________________
            1.48.88
            Fixes:
            - Switched over to use memory-mapped files when parsing scenes. This should make it so some of the larger scenes that previously failed to render will now work
            - Glossy reflections and bump map now work together properly
            - Default lights can be enabled with other lights in scene now.
            - Sketchup embedded textures show in previews now
            - Material picker handler doesn't pick mats if you hit cancel now.
            - Fixed problem with sphere plugin that caused material previews to not show displacement properly
            Changes:
            - When maps are set, the button changes color to make it more obvious
            1.48.87
            Fixes:
            - Fixed a logic error in some of the render plugin parameters that caused a memory leak
            - Fixed an issue that caused the Light Cache layout to not show properly if it was both primary and secondary engine
            - Fixed problem that caused importing materials to fail if the new material has a differet name than the material you were importing into
            Changes:
            - Added "Cast shadows" option to default material. This specifies whether or not the material will cast shadows
            - Added "Only visible in secondary" option to default material. This makes it possible to have a material only show up in reflections or refractions
            - Added "ID Color" to default material. This color allows you to set what color will show up in the Material ID VFB render channel
            - Modified the way the "Options" panel in our default material UI looks to accomodate new options
            1.48.86
            Fixes:
            - Fixed issue that made license utility not get launched on Leopard and Tiger OSX
            - Fixed problem that could occur when all layers were removed and adding new layers would be disconnected from the material
            - Made a slight modification to the Toon material that should make it so it doesn't get slower when the line width is bigger
            1.48.85
            Fixes:
            - Fixed a problem that made it so VfS couldn't be loaded on Leopard or Tiger OSX
            - Fixed issues related to the changing of installation paths for side-by-side VfS and VfR installations
            - Fixed issue that could arise if you used Google's component warehouse and grabbed two components with the same name
            - Fixed some issues that caused importing images to not work
            - Fixed problems related to two side materials being loaded / saved into our scenes
            - Fixed some issues related to our file-searching algorithm
            - Fixed it so the aspect ratio lock button will be set correctly when loading scenes
            - Fixed issue in DRSpawner that could cause it to render black
            - Fixed a problem that made it so the UI necessary to save Photon Maps was hidden
            - The file extensions for the gi maps should be filled in correctly when you go to save them out
            You can always check for the latest version on this page: http://software.asgvis.com/index.php...182&Itemid=480
            Devin Kendig
            Developer
            Chaos Group
