CORRECT SETTINGS FOR RENDERING GLASS WINDOWS
  • CORRECT SETTINGS FOR RENDERING GLASS WINDOWS
    Can anyone supply me with the correct settings for the rendering of glass windows as far as reflection and refraction
    Thank You
    Re: CORRECT SETTINGS FOR RENDERING GLASS WINDOWS
    hello, welcome...
    glass is user preference... scene and view dependant
    id go with
    DIFFUSE TRANSPARENCY set to WHITE
    DIFFUSE COLOUR is irrelevant
    REFLECTION - Fresnel - IOR 1.33 to 1.55 ( the key for the reflection is tweaking the parallel and perpendicular colours in the fresnel. By default they are at total black and white. 240 PERPENDICULAR AND 40 PARELLEL is a good starting point
    REFRACTION - ONLY use if the glass has a thickness - I usual have mine as standard ei when you first add a REFRACTION layer to the material.
    also have a look in ASGVIS.com download section.... plenty glass mats there.
    kind regards
      Thank you so much - it came out perfect.....
        also, if you set a white texAColor for the transparency texture, rather than just setting the color to white, it will make the render come out with transparency, but the viewport will still display the model as being opaque (makes it easier to interact with sometimes)
        Devin Kendig
        Developer
        Chaos Group
          nice tip.... will incorporate in my work flow!
