Introducing CROSSMAP and COLOR TOOLS for 3Ds Max (Free Beta)
  • #16
    So far, so good. Any tips on creating dozens of individual bricks, and corresponding alpha's. to be used in the mapping roll-out?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    • #17
      I am having some problems. When I open the demo wall, and render, it looks great. When I change the size, and pattern in the demo wall, it works great. The problem I am having is when I try the same thing in a real scene, I get some really strange stuff. If I leave the scale at 1 it works, but if I change it to .25, it gets all wonky. I changed the scale in both the diffused, and the displacement slot, which is instanced into the vraydisplacemod.
      The tutorials mention scale, but it never talks about it.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
      • #18
        Hi Bobby,
        sorry for the late response, I just found this post from you. Do you still have problems using Walls & Tiles with the scale parameter ?
        It is important to set the uv mapping correctly on your objects, depending on the mapping mode you are using. If you are using
        real-world-map mode, the objects also need to be set to real-world mapping.
        You can also email me directly : martin@vizpark.com
        Best,
        Martin
        About VIZPARK - www.vizpark.com
        VIZPARK is a Autodesk authorized developer of 3Ds max plugins and high quality 3D models for professional 3D artists.
        • #19
          Another bravo for Crossmap jaja
          http://www.centplay.com/affiliate/id_139/
          • #20
            thank you very much
            • #21
              thanks you verry muchh
