Vray grain is driving me insane
  • Vray grain is driving me insane
    ok so i'm trying out Vray 2 RT for the very first time and i am getting a lot of noise or grain.
    i have read lots of tutorials and searched through tons of forum threads on noise and what settings to tweak. none of that fixed my problem! i'm going crazy!
    now after tweaking various things for about a full day i managed to reduce the grain by about half but it's still totally unacceptable for my project (i will be compositing live actors shot on a dslr camera in HD).
    my model is a plastic toy castle. i have tried various materials (vray materials and standard materials, etc) and they all end up the same.
    here is a picture of my render after tons of tweaking...
    http://i15.photobucket.com/albums/a3...enderdeath.jpg
    here is a picture of my set up (just one vray sun and a vray physical camera)...
    http://i15.photobucket.com/albums/a3...scenesetup.jpg
    and here are some of my settings in Vray...
    Adaptive DMC
    Antialiasing - Off
    Adaptive DMC image sampler:
    min subs 1
    max subs 16
    clr threshold 0.005
    GI on
    Primary: Irradiance:
    multiplier 1.0
    HSph subs 40
    Show calc. phase checked
    Secondary: Light Cache
    multiplier 0.85
    Subs 700
    Sample size 0.03
    Show calc. phase unchecked
    Environment
    GI Environment (skylight) override OFF
    (when I turn this on it gets dark, have to use very high multiplier to balance it out, and the grain issue is no better)
    DMC Sampler
    adaptive amount: 0.85
    noise threshold: 0.01
    Color mapping
    ... set for linear workflow ala this tutorial http://www.jamesshaw.co.nz/blog/?p=155
    please help, i'm going crazy. and keep in mind i'm really new to all this... so if you have any tips, please explain them in a way a beginner would understand. thank you.
    Are you using the RT engine or the regular production renderer? Was not clear from your post. You mention "Vray 2 RT" but then you talk about the production renderer settings which have no effect whatsoever on the RT engine.
      hey Vlado, thanks for the response.
      well i have Vray RT set as my production renderer and material editor.
      after setting Vray RT as my production renderer, there are only two tabs in the render set up box... Common, and Vray-RT... all the settings i quoted earlier are found in the rollouts of the Vray-RT tab.
        RT is good for preview but not final render... use vray production render for rendering if u want smooth images...
          I LOVE YOU GUYS!
          problem solved!
          thanks vlado and DADAL, when i switched to the production renderer and used my regular settings it completely cleared it up.
          thank you guys sooooo much. this was driving me insane.
          have an awesome day!
            Happy to help.
            Also set up all ur material/light sampling to minimum 32 samples. It will be smooth and render at that same speed as 8...
