Thick Smoke Dissipation
  • #61
    not yet, you have to play with the transparency curve
    ______________________________________________
    VRScans developer
    • #62
      ok, thx, ill wait for dissipation
      • #63
        it's easy to work around it
        VRScans developer
        • #64
          How does this work?
          Originally posted by Ivaylo Katev View Post
          yes, definitively smoke dissipation is needed, and we will add it. currently you can workaround it using temperature based opacity+cooling.
          this is how i made this simple test
          • #65
            Your best bet is to base smoke on temperature, that way you can adjust the dissipation by using "cooling".
            • #66
              Thanks. I animated cooling and temp. Is the transperancy curve animatable?
              • #67
                some things u just cant fake
                • #68
                  i did this using cooling, no need to animate anything, the cooling "animates" the temperature for you. but now i thing the simplest way to dissipate smoke is with proper adjusted transparency curve. the natural transparency curve looks like this:
                  it approaches the x axis, but does not touch it.
                  to make dissipation effect, the curve must be more concave and can touch the x axis.
                  edit: this curve is more controlable
                  VRScans developer
