Hi all,
I have quite a few questions on V-Ray RT for GPU.
-Is there a way to pause and then set a render going again?
-Is the 'max path per pixel' the main setting for controlling noise quality?
-Are AA filter settings used?
-Do lens effects work with RT GPU?
-Is there a way to increase the hdr image resolution?
-Do frame buffers work with RT GPU?
-Does the V-Ray wrapper shader work (for ground planes)?
-Do V-Ray portal lights work in GPU rendering?
Sorry for the list (and posting here), but I've been comparing iray and RT GPU as to which to use.
Cheers,
Steve
Cheers,
Steve
