Aligning Vray cam to Max cam
  • Aligning Vray cam to Max cam
    Hey guys
    I have a problem:
    I have a 3ds Max scene with camera and lighting. Everything is made for the default scanline renderer in max, meaning the scene has max lights and a max camera.
    Now I want to have this scene completely Vray ready. The main Problem I have is the replacing of the max camera (standard Target) with the Vray cam (physical).
    I aligned the Vray cam to the Max cam and adjusted the FoV but the area to render is still a different one, it seems the Vray cam is closer...
    Is there a way to get EXACTLY the same render area?
    Cheers
    danny
    btw: I am a vray customer, just dont know how to tell my account
    you could render with your standard cams but override with exposures etc. from a vray cam
      Scripts are the easiest way honestly. I'm sure there's some on Scriptspot.com.
      Colin Senner
        Lele's vray tools...
        http://www.scriptspot.com/3ds-max/sc...les-vray-tools
        paolo vaja
        www.3d-arch.it
          Okay, thanks guys... its seems its not working properly in this scene, even with the scripts.
          So I just hang out to the normal cam..
            Lele's vray tools haven't been updated in a while 1.5RC3? However, he's still around here periodically. *Puts out the Lele Signal*
            Colin Senner
