We are having the following problem problem: VRay production renderer reads server based texture folder without any problems while the Vray RT can't seem to find the same textures and renders flat objects without textures. When we use a local directory the Vray RT reads the textures no problem. This has been going on for a while now. Anyone experienced this? Bug or missing env variable for RT? Thanks.
Vray RT not reading remote texture folder
How do you start the V-Ray RT render server application on your render slaves? Is it registered as a Widows service? If yes, you might need to change the user with which the service runs so that it can get proper permissions for accessing the network.
VladoI only act like I know everything, Rogers.
We are not using distributed rendering/ render slaves. We are each working independently on our individual workstations, but are all trying to use a central texture library that is located on a server. The production renderer can find the textures no problem, but the moment we use the same remote directory to run VRay RT all objects with textures render without them.
Here is what we get in the output window in Maya when the Vray RT render initiates:
[2012/Sep/27|08:25:46] V-Ray: V-Ray for Maya version 2.30.01 from May 11 2012, 01:51:11
[2012/Sep/27|08:25:46] V-Ray: V-Ray core version is 2.00.01
[2012/Sep/27|08:25:49] V-Ray warning: Successfully loaded "C:/ Work/tmp/Temp.hdr" for viewport environment !
V-Ray: Starting render
[2012/Sep/27|08:26:43] V-Ray: Loading plugins from "C:\Program Files\Autodesk\Maya2013/vray/vrayplugins/vray_*.dll"
[2012/Sep/27|08:26:43] V-Ray: 103 plugin(s) loaded successfully
[2012/Sep/27|08:26:43] V-Ray: Finished loading plugins.
[2012/Sep/27|08:26:43] V-Ray: Exporting scene to V-Ray.
[2012/Sep/27|08:26:43] V-Ray: Parsing light links time 0h 0m 0.0s (0.0 s)
[2012/Sep/27|08:26:43] V-Ray: Translating scene geometry for V-Ray
[2012/Sep/27|08:26:43] V-Ray: Total time translating scene for V-Ray 0h 0m 0.0s (0.0 s)
[2012/Sep/27|08:26:43] V-Ray: Rendering with IPR (port 20207).
res=true
res=true
res=true
res=true
res=true
res=true
[2012/Sep/27|08:26:43] V-Ray: Updating frame at time 1.00
[2012/Sep/27|08:26:43] V-Ray: Total time updating frame 0h 0m 0.0s (0.0 s)
[2012/Sep/27|08:26:43] V-Ray: Render complete
[2012/Sep/27|08:26:43] V-Ray: ========================
[2012/Sep/27|08:26:43] V-Ray warning: [SettingsPNG] No image writer specified.
[2012/Sep/27|08:26:43] V-Ray warning: [SettingsJPEG] No image writer specified.
[2012/Sep/27|08:26:43] V-Ray warning: [SettingsSGI] No image writer specified.
[2012/Sep/27|08:26:43] V-Ray warning: [SettingsTIFF] No image writer specified.
[2012/Sep/27|08:26:43] V-Ray warning: [SettingsTGA] No image writer specified.
[2012/Sep/27|08:26:43] V-Ray warning: [SettingsEXR] No image writer specified.
[2012/Sep/27|08:26:43] V-Ray: Preparing renderer...
[2012/Sep/27|08:26:43] V-Ray: Preparing scene for rendering...
[2012/Sep/27|08:26:43] V-Ray: Creating texture cache with size 0 MB
[2012/Sep/27|08:26:43] V-Ray: Creating bitmap manager
[2012/Sep/27|08:26:43] V-Ray: dr host: 127.0.0.1
[2012/Sep/27|08:26:43] V-Ray: Connected to render host 127.0.0.1:20207
[2012/Sep/27|08:26:43] V-Ray: Using 1 hosts for distributed rendering.
[2012/Sep/27|08:26:43] V-Ray: Preparing scene for frame...
[2012/Sep/27|08:26:44] V-Ray: Bitmap file "C:/Work/tmp/Temp.hdr" loaded.
[2012/Sep/27|08:26:44] V-Ray warning: Scene is empty.
[2012/Sep/27|08:26:44] V-Ray: Running RTEngine
I guess were not understanding one another here. We are not using render slaves. We are using a central server as a repository for all of our textures and files we are working on. We load a file from the server to our local machines. These files link to textures on that same server. When we run VRay RT on our local machine (individual workstations) everything works except the textures. The moment we move or re-link the textures to a local directory all is fine. Distributed rendering is turned off in this case.
Originally posted by plodej View PostOK that makes a little bit more sense Vlado, thank youSilly question perhaps, but how do I grab that output from the server app?
