Vray RT render problem
  • Vray RT render problem
    After I select Vray RT & render it, the screen become black color.No running.....
    I'm using 3ds max2013, Vray 2.0 SP3, windows 7 64 bits.
    Anybody know about it, please...........
    **refer to the attachment file**
    http://www.picresize.com/popup.html?...sz_capture.jpg
    help my........thanks
      I can't see the picture...
        Att picture
        http://www.flickr.com/photos/8321036...in/photostream
        Thanks.........
          "Hold your clicks a moment please...
          Flickr has the hiccups. We're looking into the problem right now."
            i not really understand,how to solve it? is it windows blocked??
              First of all, check if you have the V-Ray RT render server running - you should have in task manager a process named vray.exe - do you see it? If not, try running the RT server manually from the Start menu.
                hi, please help me check is this the problem you mention ??
                http://www.flickr.com/photos/83210361@N04/8112074321/
                  Unfortunately still can't see the image... same error as before. You can email us to vray@chaosgroup.com and our support guys will try to help you out.
