vray question
  • vray question
    i assigned a blinn for both images below:
    with mental ray
    http://i300.photobucket.com/albums/n...clouds_obj.jpg
    and with vray
    http://i300.photobucket.com/albums/nn13/sifidis/aa.jpeg
    the vray render is like the white part has a different light source. why is that?
    (both renders are made with nurbs > isoparm > detach surface)
      You are using default light sources? I guess vray default light is in different place to MR. Also I would advise against using standard BLI shaders and suggest using Vray shaders. The BLI shaders are not physically accurate as far as I remember.
        which menu are these shaders located at?
          U mean VrayLightMTL ? U open hypershade and on the left you have list of shaders... its on the top of it most of the time...
            which vray shader gives the shine of blinn? do i have to combine diferrent shaders? i can't figure it out.
              use vray material in the create shader menu
              Dmitry Vinnik
              Silhouette Images Inc.
              ShowReel:
                which particular vray shader equals blinn?
                  There is no V-Ray shader that is 100% the same as Maya Blinn one. However, you might be able to get a similar result with a VRayMtl material with Blinn BRDF and "trace reflections" turned off. Then you'll have to play with the reflection color and the glossiness to get a similar result as the Maya Blinn shader.
