We've been trying to create a water splash elements for a show we are working on. Unfortunatly I cant find a way to get rid of these lines:
Im generating the initial fill up with mel script and it is pretty much an egg shaped object gets dropped in.
Unit Scale 1
Cell Size 0.04
Max step 6
SPF upper 2
SPF lower 1
WxLxH 360x360x360
sharpness .1 or .05
Viscosity 0
Splash Treshold 18
birth rate 300000
size 0.01
size var 3
size distrub 100
air friction .9
foam on hit .6
Other elements looks good but the splash is almost split in sections. Any help would be greatly appreciated .
Unit Scale 1
Cell Size 0.04
Max step 6
SPF upper 2
SPF lower 1
WxLxH 360x360x360
sharpness .1 or .05
Viscosity 0
Splash Treshold 18
birth rate 300000
size 0.01
size var 3
size distrub 100
air friction .9
foam on hit .6
