I'm a demo user of V-Ray 2.30.01 for Max 2011 x64. Not running Max as administrator because then it can't access our mapped drives.
All the settings in the render setup keep resetting to default in the middle of working. I often have to try to capture my current settings so I can reload them, but sometimes can't do it in time... after changing 4-5 things, everything resets to default again.
For example, in the V-Ray tab I'll enable the VFB, and then assign some HDR maps in Environment. I then go to the Indirect Illumination tab. I then go back to V-Ray tab and the things I previously set will now be set to default, VFB is not enabled and the environment maps are cleared.
This seems to be random, I never know when the settings will "stick" and when they will reset.
This is especially troubling because we are evaluating V-Ray for use in our studio... but it is hard to get the "right" settings when, after tinkering for a while, everything gets set to default and my last saved preset is too old.
Please advise on what we can do to fix this.
