VRay only renders 800 x 600
  • VRay only renders 800 x 600
    Just bought and installed VRay for Rhino 5. I did the dongle registration and it now lets me render using VRay. However I am stuck rendering at 800 x 600. There is not a watermark.
    I am not sure if the licensing program is on or not. I don't see any separate program.
    I went into the VRay settings and set the resolution to higher and to override the viewport settings.
    Thanks.
    SH
    Let there B3D
    Steven Houtzager
    Intuitionusa.com
    3D Renderings & Animations for Product Development and Retail Design - Atlanta, GA
    This will sound ridiculous, but try closing and reopening the file and see if it lets you change resolution. I'm seeing an intermittent problem where you change a setting but it doesn't actually change. Usually closing and reopening fixes it.
    emil mertzel
    vray4rhinoWiki
    Lookinglass Architecture and Design
      Yes it is very strange indeed.
      Does this issue disappear or it still persists ?
        For me it is intermittent - it might disappear, it might come back. Opening and closing solves it, sometimes just opening and closing the dialog box fixes it. so I can't send a sample file. It can be something in the Vray options (but usually output size), or sometimes I see this with lights.
        SH, did this fix your problem?
        emil mertzel
        vray4rhinoWiki
          Thanks for the replys. I got it to work by clicking get view aspect button.
          Let there B3D
          Steven Houtzager
          Intuitionusa.com
            don't forget to also tick override viewport on the output panel
