Maximum Limit of Foam
  • Maximum Limit of Foam
    Is there any chance for the user to set a maximum number of foam particles?
    When working with foam on hit, I found it hard to regulate the final amount of foam particles. When foam is generated by splashes, numerous of my sims caused 3dsMax to freeze - probably simply due to particle number..
    Is it freezing during the simulation, or rendering?
    My workflow is to use very low birth value at the beginning and iterate it bigger to get best results.
      It's freezing during simulation.
      I am using the same method. However sometimes with liquids, the results of a high resolution simulation totally differs to the low res version of the same simulation set-up.
      And to me it looks like this is especially the case with foam generation. I guess that's in the nature of things with liquid. So I am slowly learning to compensate it by adjusting values. But the learning curve is not really a steep one here.
      Regardless of that, finding a way to set a limit of the maximum number of foam particles would help me to avoid these crashes.
        i understand you problem, many times i have had the same here. there is no limit of the foam, i simulate the scene at least twice (actually more than twice), first with small count of particles, and when satisfied by the birth conditions and liquid behavior, i simulate it second time with the exact birth rate value. the birth rate is strongly linear and the particle count changes the same times as the birth rate.
        VRScans developer
          Still with "Foam on Hit" at 1.0 the number of foam particles can quickly get out of hand.
            well, how many splash particles you have? are you sure that the only source of foam is the "foam on hit" option?
            VRScans developer
              I sometimes use a 0,1 value for foam birth, just to get a little bit of extra foam on top of ripple waves. I am not sure if this is the right way to go to achieve that. Anyways I can not outrule that this is what caused the crashes.
              How many foam particles can be generated by one splash particle (with "foam on hit" at 1,0) ?
              Just one?
                foam on hit is the number of foam particles generated by single splash particle. 0.1 means that one per ten splash particle will produce a foam particle. can you share a screenshot of the input panel of a problematic scene just before the max freeze?
                VRScans developer
                  I will as soon as it happens again.
