thanks Ivaylo, will try it and report back
PhoenixFDOceanTex question
can i make a request that peter stop posting photographs and passing them off as 3d? Just kidding. those images look awesome. what every your using for sky has a perfect effect on the horizon where id expect a sharp transition between water and sky in a 3d render
we spent really huge efforts to make it sharp, you can see in the very first videos it was not sharp.______________________________________________
VRScans developer
Originally posted by vlado View PostI think there's some fog involved...
Peter I have a few questions for you.
I've followed your guide from your website and everything is working good so far except I'm having difficulty emulating the background lighting and resolution from one of your HDRI's. So I got a blitzkrieg of questions
Settings:
http://i.imgur.com/jwIlPLo.jpg
Render:
I'm currently using the 0743 Cloudy Morning Sun and this i the result I'm getting. Never mind the noise, I set it low so it would render faster but I would like to know what your Vray-light dome settings, camera, and multiplier/gamma settings you're using for the HDRI. As you can see in the image I"m struggling with sun being overly bright in certain areas and dark towards the other side, it's not as consistent as in your images.. I've tried everything from tweaking the camera settings, exposure control from color corrections, but no matter what I do I can't replicate your background and get that soft light feel without it getting too harsh. Are you by any chance using a sun with the dome light or solely relying on the dome light?
In addition, the background HDRI is coming out too pixelated, which leads me to believe that you're using a bitmap on a plane? Is that correct? And finally, I noticed you have on some of the images there's a shadow being casted onto the ocean, is that from the HDRI or the fog environment? If you don't mind posting your settings I would greatly appreciate that, and will answer any questions you have for me. Thank you.
Accidently posted the settings twice without the render, here you go:
http://i.imgur.com/Pj2tclq.jpg
Originally posted by jvharten View PostPeter, Ivaylo, I'm struggling with mixing the two maps. When I use Ivaylo's suggested setup with Vraycomptex it ends up a real mess. Would it be possible to post a shot of how you did that?
