Hi all,
So I installed the PhoenixFD update (phoenixFD_adv_22000_max2015_vray_24_x64.exe)
after I uninstalled the 2.1 version (phoenixFD_adv_21000_max2013_vray_24_x64.exe).
When I start 3ds max I get the following 2 messages:
and
Any ideas how to solve this?
I'm using 3dsmax 2014 SP5 Commercial on Windows 7 SP1 (and Vray 2.4, 64bit).
Thank you very much for any help you might offer.
- j
Code:
--------------------------- 3dsmax.exe - Entry Point Not Found --------------------------- The procedure entry point ?GetInterface@MtlBase@@UEAAPEAXK@Z could not be located in the dynamic link library core.dll. ---------------------------
Code:
--------------------------- Error Loading Plug-in DLL --------------------------- DLL <C:\Program Files\Autodesk\3ds Max 2014\plugins\vrayplugins\Phoenix2.dlr> failed to initialize. Error code 127 - The specified procedure could not be found. ---------------------------
- j
