running 2.2 nightly with Maya 2014. Is it possible to export PRT files in the Maya version of Phoenix?
Phoenix FD for Maya export PRT
krakatoa for maya comes with a PRT saver that runs iterations of your particle simulation with a different seed on the emission for each iteration. I noticed that the "emission random stream seeds" attribute isnt available in the nParticles when converted from PhoenixFD particles - which makes sense as they are not being emitted. If there was a random seed on the Phoenix particles, one could run iterations of that simulation.
Hm, I'm not sure, but it may be possible to add such random number using per particle attribute and expression on creation. But since this is not done by the emitter itself, I'm not sure if you can create meaningful stream seed usng just simple expression and maybe the particle Id/creation time (you can get these from Phoenix)V-Ray/PhoenixFD for Maya developer
