Make a sound at render end?
  • Make a sound at render end?
    Hi all,
    I realize this is for the "Feature request" category but since I can't post there (asking my supervisor for our log-in credentials will be more painful than what I am willing to go through) I will post it here- is it possible to make VRay make a sound on render end? Optional, since not everybody will want it, I guess. Like a button in the Frame Buffer or a tick-box in the settings menu?
    I do render in the background quite often and knowing exactly when the render has finished will save me (and others of course) some idle time...
    Cheers.
    I second that! The whole email thing doesn't work, so some kind of notification would be great. Heck, ring my doorbell or flash my lights; it is the internet of things, after all.
    Originally posted by julianb View Post
    Hi all,
    Cheers.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      I know I'd done this before in college, so I've dug it up!
      Go to 'Customize / Preferences', Rendering tab
      There's a section for 'Render Termination Alert'
      You can set it to be a beep or play a sound file. It's in 2012, not sure if they removed it in newer versions of max. I think I had some weird .wav file play, worked really well when babysitting renders and multi-tasking
      Brendan Coyle | www.brendancoyle.com
        So if you save this as a .ms file:
        Code:
         ShellLaunch @"C:\Users\Public\Music\Sample Music\Sleep Away.mp3" ""
        And replace the path to the file with your own sound. In the render dialog where you assign a renderer, the rollout above is called scripts. Browse for the above script in the post-render section and tick on enable. It'll open your sound in whatever app is associated with it.
          cool stuff! Ask and you shall receive.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Goodness, how little do I know my 3DS Max!!!
            Thank you so much, mate.
              I just found a free small software called Text to Wav converter, which converts whatever you type in it to a .wav file.
              I used that file in the Customize / Preferences, Rendering tab in 3DS Max and now I get "Julian, your render has finished"
              Pretty sci-fi if you ask me, almost like AI in your home.
              What a great weekend
                get your geek on!
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
