Trying to make a candleflame - no luck
  • Trying to make a candleflame - no luck
    Hi
    I´m new to phoenixFD in general and completley new to fire in PhoenixFD.
    I´ve been trying to light a simple candle. Which turned out to be very hard to do (?). I´ve manage to make the candle explode, nuclear-candle, flamethrower and make it look like a bonfire....but not near enough to have a calm, smooth candle flame.
    The parameters i´ve been tweeking mostly is 'Dynamics: Gravity, timescale'. Also 'Attraction effect' and 'frame smoothing'.
    And have had best results with those - although not even close enough what im looking for. But closest..
    The straigh-forward questions are really, how do I control the shape of a flame? How do I stop it from vortexing even when I have voticity off?
    How should I do? I´ve been tweaking pretty much all parameters to make a flame - not a fire.
    Here is my closest approach together with sim. settings. The source: Inject, discharge 70, temp 2300.
    http://imageshack.com/a/img901/2140/QFiqf3.jpg
    http://imageshack.com/a/img910/6567/9ns97t.jpg
    What am I doing wrong?
    the candle simulation is harder than it seems to be. the main problem with the candles is their small scale, this requires very high spf, try with 20.
    ______________________________________________
    VRScans developer
      Also, you can have a look at an old example scene that used to be included in Phoenix:
      http://docs.chaosgroup.com/download/...412/candle.max
